12 Last
1988 Mustang 5.0 wont turn over 3500-4000 rpm's
lpp5.0
Posted: 05/01/08 07:48 PM
My 1988 Mustang GT 5.0 equipped with speed density cuts out between 3500-4000 rpms, its sounds like it isnt getting any gas once it gets to this range. I just changed the intank fuel pump, it now starts easier but still no change. The fuel pressure regulator isn't leaking at all. The cap, rotor, plugs and wires have less than 200 miles on them. Could it be a firing or a computer-related issue. Also I had the TFI ignition module tested at a Auto Zone store and it tested good. What should I try next. Please help!!!
Michael Johnson
Posted: 05/02/08 05:45 AM
Do you have an aftermarket ignition system on the car?
Michael Johnson
Associate Editor
5.0 Mustang and Super Fords
lpp5.0
Posted: 05/02/08 12:12 PM
Its the stock ignition system
mandra
Posted: 05/02/08 03:28 PM
You replaced the pump but did you replace the filter?
lpp5.0
Posted: 05/02/08 05:41 PM
I replaced the filter. Its all new stuff!!!!
lpp5.0
Posted: 05/05/08 08:16 AM
I just checked the wires, I have full spark to all 8 of them, also it has a new fuel filter
55Guy
Administrator
Posted: 05/06/08 10:36 AM
What about the ignition module? How old is it? If new, did you use the white insulating grease ont he backside of the module before mounting it to the distributor?
lpp5.0
Posted: 05/06/08 07:11 PM
Its a new NAPA ECHLIN module with less than 200 miles on it. I did put the dieelectric grease on the back of it. A few days ago I had it tested at a Auto Zone store and it tested good
lpp5.0
I also borrowed a TPS sensor at the request of a mechanic, still no change
lpp5.0
Posted: 05/06/08 07:12 PM
I have a gut feeling that it may be one or some of the fuel injectors or in the ECU(onboard computer)
lpp5.0
Posted: 05/06/08 07:13 PM
What about the pickup coil in the distributor
MY88LXSTANG
Posted: 06/04/08 08:40 AM
SOUNDS LIKE EITHER DIRTY INJECTORS OR NO INJECTOR PULSE FROM INJECTOR. TEST YOUR INJECTORS
crown504
Posted: 06/05/08 02:45 PM
i have a 93 gt convertible and i just fixed mine from that same problem. change you distributor cause its the pickup coil. i can guarantee thats your problem.
lpp5.0
Posted: 04/08/09 07:00 PM
Hello crown504. I changed the distributor and the engine sounded better but still no change, also changed the ECM, still no change. What else???? Pretty soon I'll be bringing it to the local Mustang expert
lpp5.0
Posted: 04/09/09 03:47 AM
I also thinking fuel pressure problems such as a possible clog in the fuel system: injectors or fuel rail. Who knows? I'll know soon once the local Mustang expert diagnoses it for me. If nothing good comes of it, I may convert it over to a carburetor
12 Last
