Num Posts
Posted: 01/01/07 12:29 AM
I was going down the road and tried to turn on my high beams as soon as i did all my head lights now do not work. all that works is my emergency flashers and inside dome and taillights. PlZ HELP
Posted: 01/01/07 09:59 AM
Thank you every one who at least read my problem but i figured it out I. my fuse blow. I feel so stupid I did not look at that first
Posted: 01/02/07 01:13 PM
It happens! Don't feel bad, that is how we all learn and you did figure it out on your own.
Good luck,
Steve
Member of COUGAR CLUB OF NEW ENGLAND (#25) www.necougarclub.com Member of DODGE TRUCK WORLD (Maine Chapter) http://dodgetruckworld.tenmagazines....ry.asp?id=4871
2006 Ford Mustang 1970 Mercury Cougar (19,300 miles ) 2003 Dodge Ram 4x4 Quadcab 1994 S-10 Blazer Tahoe 1968 Mercury Cougar DGS (Parting Out)
Retired Navy (Submarine Service) E-7 MMC(SS) USS Simon Bolivar SSBN-641 (B) USS Henry M. Jackson SSBN-730 (B) USS Gurnard SSN-662
Falcon67
Posted: 01/19/07 10:05 AM
Good that you found that one. Sometimes you don't think to check the obvious stuff. I would never admit to over engineering a fix to a simple problem.
You may also run into the problem where you install modern headlights and the lights cut out after a bit. The older headlight switches can get overloaded and will trip internally. Oddly enough, this problem doesn't usually show up until after dark, so it can come as quite a suprise.
