Num Posts
mbiggs
Posted: 04/08/07 12:20 PM
I am rebuilding a 289 from my 65 fastback and I have a part I can not remember what it is. It seems to fit the crankshaft. It is a thin metal round plate recessed and has a notch to fit the crangshaft key. Seems to fit around the harmonic balancer. Does this part go after the crank gear before the timing cover is on or with the harmonic balancer? I'm sure I will figure this out, but i wanted to see if anyone else used this on their rebuild or know what its purpose is? See picture.
![]() Thanks
Mike B
mbiggs
Posted: 04/08/07 04:26 PM
Commonly called an "Oil Slinger". Helps to keep oil off the damper seal, and prevent leaks. New engines don't have it. Most people trash theirs during a rebuild.
You could probably get one at the dealer.
The trick to preventing a leak there is to install the front cover so it's square to the crank snout and not the block. Install the gaskets, and the bolts hand tight. Slid the damper on so the hub just barely enters the seal. Move thr front cover around until you have even seal compression around the circumfrence.
Falcon67
Posted: 04/08/07 07:39 PM
Yes, it's the oil slinger. I goes on the crank after the crank gear goes on, behind the timing cover.
