removing ignition cyclinder from dash - Modified Mustangs & Fords Forums at Mustang & Fords Magazine
User Name:
Password:
Join FREE Now!
Forgot Password?
Forgot User Name?
Remember Me
Get Adobe Flash player
Rss
msc805 msc805
New User | Posts: 1 | Joined: 09/07
Posted: 09/17/07
09:52 PM
hi,
Is there any easy way to remove the ignition cylinder from the dash when you don't have the key. I picked up a parts car and am trying to strip out everything I can.
thanks
mustero mustero
New User | Posts: 1 | Joined: 01/08
Posted: 01/17/08
03:22 PM
What year??? The only way I know is drill.If it is a 65-66 you have to remove the cylinder to remove the bezel
If it is a 67-9 you can remove the bezel and then pull the whole switch out.If you can use a lock pick...
Good luck
Truth is Truth weather YOU believe it or notmustero
www.bigdmustangs.com
bills66pony bills66pony
New User | Posts: 1 | Joined: 02/08
Posted: 02/18/08
05:53 PM
straighten out a paper clip and insert it into the hole below the key hole. this releases a pin, any key(or other similar item) then inserted into the key hole and turn the key and the cylinder will release from the dash.
good luck
Ford Mustang Research
Ford Mustang Explore the new Mustang and examine the various features it has to offer. The 2011 Mustang goes for a suggested retail price of $34,645.00, and comes with comparable warranty coverage to other vehicles in its class. You also might want to research the Mercury Sable and the Ford Shelby GT 500.
