Num Posts
msc805
Posted: 09/17/07 08:52 PM
hi, Is there any easy way to remove the ignition cylinder from the dash when you don't have the key. I picked up a parts car and am trying to strip out everything I can. thanks
mustero
Posted: 01/17/08 02:22 PM
What year??? The only way I know is drill.If it is a 65-66 you have to remove the cylinder to remove the bezel If it is a 67-9 you can remove the bezel and then pull the whole switch out.If you can use a lock pick... Good luck
Truth is Truth weather YOU believe it or not![mustero]() www.bigdmustangs.com
Posted: 02/18/08 04:53 PM
straighten out a paper clip and insert it into the hole below the key hole. this releases a pin, any key(or other similar item) then inserted into the key hole and turn the key and the cylinder will release from the dash.
good luck
