New Heater Core - Modified Mustangs & Fords Forums at Mustang & Fords Magazine
New Heater Core
User Name:
Password:
Join FREE Now!
Forgot Password?
Forgot User Name?
Remember Me
Get Adobe Flash player
Rss
New Heater Core
matts68 matts68
New User | Posts: 30 | Joined: 11/07
Posted: 02/12/08
09:18 AM
Hey Guys,
    Completed rebuild of the ventilation system in the 68 (no ac).  Cannot get water to circulate through the heater core.  Any Suggestions?
Mike
MustangMan MustangMan
Moderator | Posts: 410 | Joined: 07/06
Posted: 02/12/08
12:28 PM
Did you reuse the vacuum valve in the heater hose between the engine and firewall? Maybe it is stuck closed? Did you check its functionality with a vacuum pump?
HTH...
Mark
Editor
1966 Mustang 289-4V/C4
1990 Mustang 347/AOD
matts68 matts68
Posted: 02/12/08
01:37 PM
You got me there - did not find a vacuum valve.  Hooked the hose directly through the firewall to the core. Any more info on this vacuum valve that obviously needs to be installed?
Thanks
Mike
Falcon67 Falcon67
Enthusiast | Posts: 473 | Joined: 12/06
Posted: 02/13/08
07:06 AM
Parts America (Advance Auto) #74612
http://www.partsamerica.com/ProductList.aspx?PartType=394&PTSet=A
It's a 4 Seasons part - don't be suckered by the $70 part on ePay.
1967 Falcon 4 door 351C-4V
1970 Mustang 351C-2V
Owner built, owner abused.
matts68 matts68
Posted: 02/13/08
08:55 AM
Thanks Falcon - where does this valve get installed?
Posted: 02/13/08
11:52 AM
The valve is installed in the inlet hose to the heater core, but with the hose going straight to the core without this valve you SHOULD be getting heat. Does the blower motor work? Are you getting air out of the floor vents? Maybe you have a jammed or inop blend door and it isn't allowing air through the heater core...
HTH...
Mark
Editor
matts68 matts68
Posted: 02/13/08
12:06 PM
Agreed Marc - everything works. I think the vacuum valve is simply a block valve when A/C is running.  No A/C on this car.   new motor, new plenum.  Getting air everywhere.  The inlet hose gets hot,  outlet hose stays cool.  Too much backpressure on water pump suction? Heater core plugged?  possibly.  Installed new heater core while I had it apart.  There were two OD plugs when the core arrived.  I did not bother the check if there were any additional plugs other than the 2 I removed.  may get the DA award on this one.
Mike
matts68 matts68
Posted: 02/13/08
03:43 PM
heater core blocked, sorry to waste your time. Mark, you should start with me as the first dumb a#$ award
I think that I will wait until the weekend to get back under there
Posted: 02/14/08
09:54 AM
Glad you found the problem. No need to get that trophy engraved just yet, I'm sure we've all jumped to conclusions and bought a part we didn't need or installed something while another sister part sat on the workbench (like putting the wheels on before the brake caliper!)...
Good luck with the fix this weekend. I'll be in the garage myself working on the Cobra's interior, installing the replacement windshield, and starting a list of sheetmetal needed for the boy's '68 coupe we just got...
Later...
Mark
Editor
matts68 matts68
Posted: 02/14/08
03:47 PM
is that the gold  coupe?
Posted: 02/15/08
07:28 AM
No Mike, the gold '66 coupe in my reader's ride section is my car. I built that from '99 to '04 when I worked on another magazine. It's a replica of the '66 I drove in high school (my first car) except this one has A/C and a little more power under the hood. It's my weekend time machine so to speak.
If you read the blog section (does anyone?) we just picked up a '68 coupe for my 15 year old son Kyle as his first car. It's going to be a father/son project to hopefully bring us a little closer together. We just got it two weeks ago and it's stripped down to just the glass, wiring, and suspension right now. We need to get it in the garage and on stands and start taking the rest of it apart and evaluate the sheetmetal so we can start the series on it.
Have a good weekend...
Mark
Editor
Ford Mustang Research
Ford Mustang Explore the new Mustang and examine the various features it has to offer. The 2011 Mustang goes for a suggested retail price of $34,645.00, and comes with comparable warranty coverage to other vehicles in its class. You also might want to research the Mercury Sable and the Ford Shelby GT 500.
