Num Posts
fordmanny
Posted: 03/10/08 09:57 AM
So i swapped out my engine for a 93 Mustang 5.0 H.O. with the whole serpentine pulley setup. I'm going carbureted until i can get the computer to put in the fuel injection installed. I'm having issues with the lower radiator hose. Can someone give me a part number that will fit with the stock radiator and the new engine, as the old radiator hose rubs against the serpentine belt? any suggestions???
Posted: 03/11/08 06:47 AM
Are you using the stock Mustang radiator with the outlet on the passenger side? If so you'll need to fabricate a steel coolant tube, use a flex hose (either rubber or something like a Cool-Flex), or purchase the hose adapter kit from Ron Morris Performance...
HTH... Mark
