Item Posts
converting vinyl top to hardtop...help!?
ryann1967
Posted: 03/24/08 01:30 PM
hi. i have a 1967 mustang, it has a vinyl top, which is not in the greatest of condition, and i never wanted one in the first place...is there any way it can be removed to reveal the hard top underneath? How would i go about doing that? is it worth it?
please help!
Posted: 03/24/08 01:44 PM
If you remove it, the hardtop color most likely would not match the rest of the car. Depending on how old your paint job is, the sun ect... will fade a paint job. I have one on my 68, but have never removed it. I'm not sure if these are glued down or not. I would imagine there has to be some sort of adhesive to hold them on. Unless you plan on repainting the entire car, I would replace the one you have. New vinyl tops are really reasonable. My 2 cents worth.
john
ryann1967
Posted: 03/24/08 04:58 PM
well i got the car about 6 months ago, and with a brand-new paint job, same as the original color, but in better condition - of course...
any other suggestions, as I really do like hardtops much more...?
Posted: 03/24/08 07:34 PM
well, you should be able to pop off the chrome strip above the rear 1/4 panel. if you rotate the chrome strip up it should pop off. maybe then you can see if the vinyl top has beeen glued otherwise I would go to the person that painted it and see what they did when it was installed.
john
Falcon67
Posted: 03/25/08 06:10 AM
All vinyl tops are glued, AFAIK. To get it off, remove the trim and use a heat gun to start peeling it off. It's just work. Hate 'em, personally. I'd rather drive a half primered car than one with a crappy vinyl top on it.
ryann1967
Posted: 03/26/08 07:57 AM
thank you for the help everyone. I guess I'll have to set some time aside for this project, but its definitely worth it NOT to have a vinyl top!
Posted: 07/23/09 06:37 AM
hey Ryan, did you ever get the vinyl roof removed? if so, how did it come out? did you find any rust underneath?
