Item Posts
390 BUILDUP
rusty43
Posted: 04/01/08 09:20 PM
I HAVE A .030 OVER, 1969 BLOCK THAT CAME OUT OF A MOTORHOME. I WANT TO KNOW WHICH CAM TO INSTALL TO MAKE GOBS OF TORQUE AT 5K RPM (SO IT WILL LAST A LONG TIME) 1968 NOTCHBACK WTH A C6 IS THE PROBABLE PROJECT CAR. REAR RATIO TO BE DECIDED. ALUM DUAL PLANE WITH 750 CFM 4BBL. I WOULD LIKE GUIDANCE ON CONVERTER STALL AND WHETHER I SHOULD INSTALL TRANS BRAKE AND/OR GEAR VENDORS OVERDRIVE. THIS WILL BE PRIMARILY USED ON THE WKND AT THE STRIP WITH SLICKS BUT OF COURSE WOULD HAVE TO CRUISE SOME DAYS AS WELL. YOUR THOUGHTS? THANKS.
Falcon67
Posted: 04/02/08 08:29 AM
The absolute best source of info on the Ford FE series is found over on fordfe.com. Really. Better than a book.
rusty43
Posted: 04/02/08 06:17 PM
Thanks Falcon, I'll check them out.
