Num Posts
Orange78
Posted: 05/19/08 04:49 PM
My question is has anyone put a T-5 in a Mustang II. My uncle and I are wanting to do this before I go to School. We are wondering if there is anything we should no before doing this. Its a 302 4-speed already but the 4-speed is crap so if you can help I would appreicate it.
Falcon67
Posted: 05/20/08 05:09 AM
Check out the Mustang II network T-5 Swap Tech Page
Orange78
Posted: 05/20/08 11:44 AM
Thanks for that link but he used the belhousing from the 4-speed. We want to know if and how a T-5 belhousing would work for the Stang II.
Falcon67
Posted: 05/20/08 08:16 PM
Got this from the mustangsandmore forum
Unread 04-22-2007, 09:48 PM Tom G Tom G is offline Sage Join Date: Nov 2001 Location: Bethlehem Pa Posts: 1,277 Default Will a T5 fit a Mustang II? A friend of mine has a 77 mustang II with a V8 and stick he is looking to put a 5 speed in it. Has anyone tried a conversion? Thanks! __________________ 67 Fastback Clearwater Aqua, GT40X motor 650DP RPM Air Gap, FPA 347 STEP HEADERS, Z rated T5 3.89 9" 100 shot giggle gas 331rwhp NA 427 w 100 shot best ET 13.11@111mph
69 Boss 302 Acapulco Blue project 65k original miles needs everything though #s match Last edited by Tom G : 04-22-2007 at 09:51 PM. Reason: spelling Reply With Quote Multi-Quote This Message Tom G View Public Profile Send a private message to Tom G Send email to Tom G Find all posts by Tom G Add Tom G to Your Buddy List #2 Report Post Unread 04-22-2007, 11:44 PM UnbridledFury's Avatar UnbridledFury UnbridledFury is offline Sage Join Date: Jun 1999 Location: Tacoma, WA Posts: 1,886 Default Yes, it has been done before. Not sure of all of the things that have to be modified to make it work, but it can be done.
Here is an example of a Mustang II that it has been done to. http://www.cardomain.com/ride/858154 __________________ Motor Safe!
George
1975 Mustang II 2+2 1975 Mustang II Ghia 1994 Ranger XLT 4X4 (229,000+ miles) 2000 Windstar
M&M Member #47
US Army, Retired
Madness takes its toll. Please have EXACT change!! Reply With Quote Multi-Quote This Message UnbridledFury View Public Profile Send a private message to UnbridledFury Send email to UnbridledFury Visit UnbridledFury's homepage! Find all posts by UnbridledFury Add UnbridledFury to Your Buddy List #3 Report Post Unread 09-28-2007, 12:48 PM jeffnoel jeffnoel is offline Journeyman Join Date: Jan 2007 Location: Clovis, CA Posts: 6 Default Here you go.
http://www.mustangii.net/t5swap.asp Reply With Quote Multi-Quote This Message jeffnoel View Public Profile Send a private message to jeffnoel Send email to jeffnoel Find all posts by jeffnoel Add jeffnoel to Your Buddy List #4 Report Post Unread 09-28-2007, 01:04 PM regalsnake7887 regalsnake7887 is offline Journeyman ~ Supporter Join Date: Jan 2004 Location: Kenora, Ontario, Canada Posts: 33 Default T-5 conversion I have a T-5 in my 78. I used the bell housing, clutch and transmission from an '84 Mustang GT. If you use the MII bell housing, I understand that you need to shorten the input shaft of the tranny. My setup requires that you cut the tunnel, as the shifter moves forward about 2 inches. This also requires a mod to the centre console. Presently, I am using the console without the shifter bezel, until I figure out something new (stainless, plastic or ???). The net result is that the shifter is a little too far forward, and I want to change it to one that curves farther back. Hope this is helpful.
Rick Reply With Quote
Orange78
Posted: 05/20/08 10:22 PM
Thanks for that, this has helped but some stuff I still need to know. But this has opened the path a little wider. Thank you for the info Falcon67
Falcon67
Posted: 05/21/08 10:17 AM
Good hunting - owned two MIIs in the past, miss having one around.
Posted: 05/22/08 06:54 PM
hi,i installed a t-5 in a 76 cobra II using the 5 speed bellhousing and stock exhaust manifolds, i,m not sure if you can get a header that will clear the clutch fork. you will have to open the shifter hole in the floor a little bit but other than that you shoudn't have any major issues. some modification to the tranny crossmember my be required also. good luck.
78 COBRA II-302auto 79 MUSTANG-460auto 64 fairlane-260 4sp 64 fairlane-pending
Orange78
Posted: 05/22/08 08:30 PM
Oh ok that doesn't sound to bad. I'm guessing you had get your driveshaft re-lengthed. But just found some headers on summit hopefully they will work. But thanks for the info
Posted: 06/03/08 06:13 PM
sorry i been gone so long, busy schedule! actually i did use the stock length driveshaft but i changed to a longer yoke i had lying around,i think it was out of an older mustang but i'm not sure(i've parted out too many cars!)if i remember correctly the mustang II v-8 driveshaft will be about 1" too short because of the depth of the stock mustang II bellhousing and i used the longer yoke to compensate for the length.i hope you have picked a good tranny(example:early 90's world class)because mine was from a 84 1/2 turbo capri(non-world class, but i wanted the short first gear). it was a blast to drive even though the motor didn't make much hp. then i ended up ripping teeth off the imput and counter shafts! too many 6000 rpm holeshots and power shifts but hey, drive'em to break'em and build'em to take it! i soon replaced it with a toploader 4 speed and life was good again, but that was when gas was cheap and with todays prices, you will need that 5th gear.good luck
Orange78
Posted: 06/11/08 07:08 PM
Ok thanks but my uncle suggested to by a new tranny it would be better down the road. But thanks for the help.
