Num Posts
Posted: 08/21/08 06:01 PM
THE CODE ON THE INTAKE MAINFOLD OF THIS ENGINE IS DOAE9024L OR DOAE9025L-TELL ME ALL YOU KNOW ABOUT IT. SHE SITS IN A 1966 FORD F100 NOW...I'M ANXIOUS TO HEAR ABOUT HER...
Falcon67
Posted: 08/22/08 05:41 AM
That's a casting number and you probably mean 9425?
D0 - 1970 A - Full size E - Engine group 9425 - intake manifold L - revision level
That's all that number says.
There will be a block casting number over the starter, that would help a little more. Heads should have a "4" cast in the corners where the valve cover attach. Intake is probably an iron 4V from a 70 or 71.
Posted: 08/22/08 05:42 AM
You sure it isn't -9424-, as that's Ford's base PN for an intake manifold...
D0AE denotes 1970 (D is decade, 0 is year)Ford car line engine part...
What you need is to find the similar number on the block itself, cast in just above the starter mount. That'll allow you to find out more about the engine block's oriignal ID/Specs...
Either post back here or when you find the number do a Google search...
You can also find a lot of info on Falcon67's page at www.raceabilene.com/kelly/hotrod/
HTH... Mark
Posted: 08/24/08 04:15 PM
Thank you for the information. I am going to look for the other numbers so that you can tell me more about my 351C. I rebuilt her myself about 25 yrs ago and just didn't have the knowledge base I needed to know about her specs. I am in the process of restoring her and I appreciate all the help I can get. Thanks again. Keep in touch.
Posted: 08/24/08 04:17 PM
1COOKIEMAN: THE CODE ON THE INTAKE MAINFOLD OF THIS ENGINE IS DOAE9024L OR DOAE9025L-TELL ME ALL YOU KNOW ABOUT IT. SHE SITS IN A 1966 FORD F100 NOW...I'M ANXIOUS TO HEAR ABOUT HER...
artstang
Posted: 10/02/08 08:22 AM
DOAE-9425-L is listed as Ford 1970 351C 4 barrel cast iron intake manifold.
Artstang 73 Mach1, 351C-4V Ram Air 67 Eleanor convertible 05 Sport Trac 4x4 (DD) 04 EB Explorer AWD
