65 mustang 289 2V - Modified Mustangs & Fords Forums at Mustang & Fords Magazine
65 mustang 289 2V
User Name:
Password:
Join FREE Now!
Forgot Password?
Forgot User Name?
Remember Me
Get Adobe Flash player
Rss
65 mustang 289 2V
classicman classicman
New User | Posts: 1 | Joined: 08/08
Posted: 08/29/08
05:35 PM
Hi all,
I am new here and just bought a 65 mustang conv. What type of gas do you recomend for a V8?
Looking forward to learn for all of you.
artstang artstang
New User | Posts: 20 | Joined: 10/08
Posted: 10/03/08
12:57 PM
Classicman, if the cylinder heads on your 289 2V motor still the original and it doesn't have hardened valve seats installed then I recommend using leaded gas if driven daily. But it is hard to find leaded fuel and most people use unleaded fuel and add lead additive. If hardened valve seats were installed then use unleaded gas.
Artstang
73 Mach1, 351C-4V Ram Air
67 Eleanor convertible
02 S281 SC Saleen conv.
05 Sport Trac 4x4 (DD)
04 EB Explorer AWD
mazestang mazestang
New User | Posts: 1 | Joined: 08/09
Posted: 08/14/09
05:27 PM
i have a 67 with original 289 v8, but not sure it has hardened value seats.  Anyone know how can I verify?
Falcon67 Falcon67
Posted: 08/14/09
09:04 PM
It won't have hardened seats.  But - it's not a problem.  Run whatever fuel grade is necessary to prevent pinging and it'll be just fine.  Valve seat recession is possible - over an extended period of time.  EXTENDED being the key word.  If the heads ever get redone, a proper seat cut will lessen the chance of seat recession without having to install hardened seats.
1967 Falcon 4 door 351C-4V
1970 Mustang 351C-2V
Owner built, owner abused.
slud slud
New User | Posts: 31 | Joined: 02/09
Posted: 08/18/09
02:06 PM
I built up a 73 351W motor for my 80 Ford Van, and I put about 75,000 miles on it before the valves beat up in the heads. So what you need to ask yourself, 1. Is this going to be acruise car, with very little miles being put on it? If so, the Lead additives will alllow you to not bother the motor. 2. Does the motor need to be rebuilt? If so, a set of E7TE heads for stock would be a choice, Iheard they were good heads, unless someone has abetter suggestion, I'd sure like to hear!!! I'm talking budget build, now, but around here, in Athens, OHIO, To do a complete Hardened seat set and valves is 400 - 500 dollars. You would have to check in your area for prices.Please check with a local Ford Car Club, you could get some good advice, and a good set of heads for a little of nothing, and someone might even help with the swap!!! Some of us can't get enough of playing around with old cars!!!!
Ford Mustang Research
Ford Mustang Explore the new Mustang and examine the various features it has to offer. The 2010 Mustang goes for a suggested retail price of $20,995.00, and comes with comparable warranty coverage to other vehicles in its class. You also might want to research the Mercury Sable and the Ford Shelby GT 500.
