65 fairlane front end alignment specs. - Modified Mustangs & Fords Forums at Mustang & Fords Magazine
User Name:
Password:
Join FREE Now!
Forgot Password?
Forgot User Name?
Remember Me
Get Adobe Flash player
Rss
dean007 dean007
New User | Posts: 15 | Joined: 09/08
Posted: 10/18/08
06:24 PM
Can anyone give me info on the specs for my 65 Fairlane??
waynep712 waynep712
New User | Posts: 42 | Joined: 05/08
Posted: 10/19/08
09:26 AM
camber....
left... 1/2 degree positive
right 1/4 degree positive..
(tires leaning out a tiny bit at the top.. but not noticeable, the left keeps the car from drifting to the right do to the crowns on the roads...)
caster... 2 degrees negative. if you can crank that much into it...
(the upper ball joint will be behind the lower so the wheels will lean into the turn... makes them go around corners better..)
toe in... 1/8"   to 3/16" measured 6 inches up. from the ground..   this varies do to how much play there might be in your steering linkage and suspension
hope this helps.... and it is not what the factory called for...     that was before cars were designed to go around corners well...  or wide tires.....
be sure that you check the strut rod mounting boxes...  they sometimes come loose...
dean007 dean007
Posted: 10/19/08
03:39 PM
Thanks, I'll pass these along to Goodyear. Their charts don't go back that far.
Falcon67 Falcon67
Enthusiast | Posts: 474 | Joined: 12/06
Posted: 10/20/08
06:22 AM
-2 caster?  It'll drive like a waterbed.  You would do better to dial in as much + caster as you can, +1 better than nothing, 2.5~3 best.
1967 Falcon 4 door 351C-4V
1970 Mustang 351C-2V
Owner built, owner abused.
dean007 dean007
Posted: 10/20/08
09:31 PM
Falcon67,, I did find specs in my repair manual. Caster is listed as -1 to +1. What will staying on the + side do for me?? thanks
Ford Mustang Research
Ford Mustang Explore the new Mustang and examine the various features it has to offer. The 2011 Mustang goes for a suggested retail price of $34,645.00, and comes with comparable warranty coverage to other vehicles in its class. You also might want to research the Mercury Sable and the Ford Shelby GT 500.
