Item Posts
92 f150 engine swap
aduck
Posted: 03/11/09 03:33 PM
i wanna put a 302 ho out of a mustang in my truck need any help on what im gettin into got the motor just wonderin how well its gonna go in is the intake gonna have to be changed or will it work any help
Posted: 10/31/09 12:04 PM
The big questions you will have for this is EFI (fuel injection) and transmission.
I'm assuming if you're wanting to go to a 302 that you have a 300/L6 in it now (I mean why go from a 351W to a 302?) I looked up the 92 F150 on a Autozone & Advance Auto websites and apparently all 92's were EFI. So, the first question becomes what type of intake manifold is on your 302HO? Is it carb'ed or EFI/TBI? If it is a carbureted manifold then I would suggest taking a EFI manifold and motor wiring harness off of a junkyard engine. Its cheaper to do that than buying one aftermarket, but it is more of a headache. The second question, that is beyond my ability to answer, is plumbing, wiring & programming the fuel system and computer from an L6 to a V8.
For the tranny, I don't know what type transmission you have, and don't know if the L6 has the same bell-housing pattern as a 302/351 V8. If your transmission has a detachable bell-housing (like the T5 for instance), then all you have to do is get the correct one for that engine/tranny combo. If your transmission has an integral bell-housing then you have to get a transmission that will mate to the 302.
HTH...
67 Mustang Coupe 302 .040 / C4 / 8.8
