89 FORD TRUCK WIPERS ? - Modified Mustangs & Fords Forums at Mustang & Fords Magazine
User Name:
Password:
Join FREE Now!
Forgot Password?
Forgot User Name?
Remember Me
Get Adobe Flash player
Rss
r_davis37745 r_davis37745
New User | Posts: 1 | Joined: 03/09
Posted: 03/14/09
10:24 AM
HI  I have replaced the wiper motor and switch in my truck but the wipers still hesitate. when they hesitate the volt meter drops 3  volts until they start moving again. its like they work fine for 3 minites then they start screwing up. it will get worse until they stop.  do they have a resister or something.  i dont know what else to do. please help...  r
MustangMan MustangMan
Posted: 03/17/09
05:37 AM
I'm assuming this truck has intermittent wipers? If so it is usually a separate module (under the dash, oftern with a sticker that says fragile/do not drop). It's possible the voltage, even on low or high speeds, still passes through the intermittent wiper module and the issue is in the module? I'd also check for good solid grounds. Often the wiper motor is case grounded and there could be an issue with not enough grounding going on. Try running a decent ground wire from one of the motor's mounting bolts to a fender bolt, engine block bolt, or even right to the battery negative terminal and see if it helps...
HTH...
Mark
Editor
1966 Mustang 289-4V/C4
1990 Mustang 347/AOD
Ford Mustang Research
