No power to coil - Modified Mustangs & Fords Forums at Mustang & Fords Magazine
No power to coil
User Name:
Password:
Join FREE Now!
Forgot Password?
Forgot User Name?
Remember Me
Get Adobe Flash player
Rss
No power to coil
topmill topmill
New User | Posts: 5 | Joined: 10/09
Posted: 10/18/09
03:42 AM
I'm in the process of putting together a basket case 1970 Mach 1. It's a 351C with 4 speed, no A/C, no tach. When I got it, it had a big aftermarket coil mounted on the fender well. I took that off and now have a stock coil mounted on the engine in it's correct factory location. The problum is when they ran the coil wires to the fender they cut the original coil wire harness end off and ran extra wire to the coil. I ordered a new coil wiring harness but had nowhere to plug it into. (they had cut the plug off the wiring harness at the firewall) Soooo I went to the wrecking yard got the plug off an old Ford and soldered it to the wires they had cut. Now everything looks good but no power to the coil. I have read that there should be a resistance wire in line (pink?)to drop the voltage from 12 volts to about 6.5 volts to the coil. I checked the resistance of the new coil harness but there is no added resistance to that wire. Someone said that there is a pink wire under the dash that should plug into a black wire for those cars that don't have a Tach. I pulled my dash out and searched for a loose pink wire, Nothing. HELP
waynep7122 waynep7122
New User | Posts: 11 | Joined: 10/09
Posted: 10/18/09
05:43 PM
did you check it all the way back to the ignition switch...  perhaps they cut the wire there.. to send it to the inner fender mounted coil..
here is a picture of the ignition switch...
http://www.mustangmonthly.com/howto/173_0310_mustang_ignition_switches/photo_04.html   you can see the pink wire in the photo...
here are the 3 different ballast resistor wires that AZ should be able to get..
Duralast / Ballast Resistor Part Number: F799
Application: With 2 wire connector
49" in length (Resistance wire)
Duralast / Ballast Resistor Part Number: F796
Application: 61" in length With 2 wire connector
Duralast / Ballast Resistor Part Number: F797
Application: With 3 wire connector
one last thing... i take it that you are going to install an electronic ignition system..    so you might want to verify what kind of voltage you will need at the ignition module..
you might also check that the bypass circuit from the starter relay is still working..
MustangMan MustangMan
Posted: 10/19/09
06:41 AM
Nice reply Wayne! Thanks...
Didn't get a chance to look through the forums, as I had a super busy weekend...
Mark
Editor
1966 Mustang 289-4V/C4
1990 Mustang 347/AOD
slud slud
New User | Posts: 31 | Joined: 02/09
Posted: 10/19/09
02:46 PM
Just a thought... If you are going to do a lot of work yourself, call your local parts store, and see if they can get you a Chiltons or a Haynes manual for your Mustang. They have a good wiring diagram in the back,plus a lot of other good info. Sounds like you are going to have some other issues with electrical problems as well....so invest in a good test light, and good voltmeter you'll be glad you did.
Posted: 10/19/09
08:42 PM
the autozone.com beat you to it...
 REPAIR INFO   REPAIR GUIDE  CHASSIS ELECTRICAL  WIRING DIAGRAMS   WIRING DIAGRAMS
Ford Mustang/Cougar 1964-1973 Repair Guide
and they are printable and free ...  there is another bunch of stuff covered and more years of mustangs... and 71 up midsize..
thanks mark... i try my best all over the various forums..
Falcon67 Falcon67
Posted: 10/20/09
05:04 AM
The pink wire should be under the dash, running from the ignition switch into the harness.  Verify the wiring to the solenoid also, it may be wired to provide crank power to the coil.
Wiring diagrams here: http://midlife66.com/wiring/wiring.html
1967 Falcon 4 door 351C-4V
1970 Mustang 351C-2V
Owner built, owner abused.
topmill topmill
Posted: 10/26/09
12:44 PM
Thanks for all the help. After countless hours of troubleshooting I found the problum. It was me. Agggg. The plug end that I got at the wrecking yard and soldered into my wiring harness had all the right colors but were not in the correct order. So my 12 volts was there except it was going to the oil sending unit. One more trip to the "yard" also known as the "happiest place on Earth" according to my Wife, I found the right plug. Installed it and My Baby came to life for the first time. (Full restoration) Thanks everyone.
Posted: 10/26/09
02:31 PM
Glad to hear you figured it out. Progress always feels good doesn't it!
Mark
Editor
topmill topmill
Posted: 10/27/09
03:42 AM
Yes it was a nice feeling, that was intill I found out I have no gauges....
Ford Mustang Research
