1958 ford fairlane power steering - Modified Mustangs & Fords Forums at Modified Mustangs & Fords Magazine
Facebook
User Name:
Password:
Join FREE Now!
Forgot Password?
Forgot User Name?
Remember Me
Get Adobe Flash player
Rss
klassic klassic
New User | Posts: 3 | Joined: 01/12
Posted: 01/20/12
03:21 PM
Has anyone installed a Borgeson Manual to Power steering Conversion Kit
#BRG800115 on a 1958 ford fairlane 500 (352 CI Interseptor)?
If so how did it install and perform? How about installation brackets
also.  I would appreciate any feedback on this.
waynep7122 waynep7122
User | Posts: 146 | Joined: 10/09
Posted: 01/20/12
11:45 PM
did you look at the borgeson web site.. this is what they posted about it..
Borgeson now offers an integral power steering conversion for your 1952-1964 Full-Size Ford car. The Borgeson conversion box is a remanufactured modern integral power steering gearbox. The Borgeson integral power steering gearbox provides true modern power steering feel, feedback and a sporty 16:1 ratio. Borgeson has remanufactured this box to bolt directly to the factory mounting location and to fit the stock steering linkage with the included pitman arm without any interference or modification of the frame. The original factory column will need to be shortend for clearance power steering box. Cars with factory power steering will require either a drag link adapter or a manual steering center link. Eliminate your leaky control valve and feel the road with a new integral power steering conversion from Borgeson.
IMPORTANT INSTALLATION NOTES
NOTE: Steering column must be shortened to fit conversion box.
NOTE: Steering column modifications can be extensive on column shift cars.
NOTE: Power conversion box may not fit with factory clutch linkage.
most of the forums are really slow right now..  there are also a bunch of other magazines on this site that might have actually covered this swap also..
hang on for a response...   the staffers usually read the new posts on early in the week..
i also noticed that this seems to be a newer kit..
klassic klassic
Posted: 01/23/12
04:00 PM
I appreciate the info-maybe someone has installed this unit...
