400C tune question
ltdmonk
Posted: 10/22/07 01:17 PM
just installed a dual exhaust 2.5in set up(turbo mufflers)on my 74 LTD. its at 10'BTC now. whats a good to enhance all around, advance or retard some degree's. it feels stronger now, it kinda bogs when cold or cool is this normal now.
seeking any tune sugestions. 2K miles on accel 576 plugs,D1AE heads,accel super coil, new cap & rotor. carb dialed in at about 12:1. now the exhaust work is complete. P.S it's my daily driver...
Bowing deeply  Smile
Falcon67
Posted: 10/23/07 06:00 AM
Open chamber heads like 12+ initial, maybe 38~42 total in by around 3000.  Depends - the 400 typically has such massive deck clearance that you have to walk the line between performance and detonation.  Open chamber heads are really, really "slow" - our race 2V engine has 18 initial, 38 total in by 2500.
If the carb is a stocker, not sure what you can do about cold driveability - probably not much.  sounds like you need a hair more pump shot, maybe a step more jet but you can't just go buy those parts for a Ford carb.  If you want better tunability in the carb department, consider the Edelbrock carbs.  A 1406 600 CFM is a very good street carb and you can buy plenty of turning parts for it.  It also comes with very good tuning instructions.
1967 Falcon 4 door - 351C
1970 Mustang coupe - 351C
Owner built, owner abused.
ltdmonk
Posted: 10/23/07 01:57 PM
Hey thanks to all who have read my question so far.. thanks falcon67 for the tip. I will set it at 12 dg -thats factory-and see what happens.. the carb is a holley 2v stocker, i notice that the choke has a mind of its own some days..
it takes the mixture and idle adjustments to seriously. when i swaped the heads i saw that room in the bores. maybe i will get lucky on an aussie set soon. a intake and edelbrock 4v can be next
LuV that vid of your falcon on the 1/8 mi...          Bowing deep Ooo
Falcon67
Posted: 10/23/07 08:11 PM
You can find lots of parts for that 400 here:
http://www.tmeyerinc.com/
Beware the Aussie heads without the proper pistons and deck clearance - the motor will hammer itsself to death.  TMeyer can supply pistons that match the small chamber and fix the deck clearance problem.  A tight quench distance helps octane tolerance tremendously.
ltdmonk
Posted: 10/24/07 01:18 PM
I went to the link and learned a few things. later if I were to completly rebuild the engine. I wuold score some of those pistons to help compression. comp cams techs advised of a R/V grind 252 or 260 grind for lots of torque. there was a "high torque engines" build up on hot rod mag (sept 98)and chose a 400M.
with basic block work,alot of decking,some porting(2V heads)and a comps cam extreme energy 268 with cam at 9.5:1, they pulled 375hp and 450ft lbs. I still have a copy of that article and meditate on that day to try something like that.
and to think I almost bought a set of ausie heads at the swap meet(pomona)
last year... Thank you for you're coments..  Bowing deeply  Laugh
ltdmonk
Posted: 11/04/07 08:20 PM
i write to update all reading this post.
time and carb are perfect and is running
GREAT! it knoks & pings a little at the right amount of pedal but, all around very
good... agian thanks to Falcon67 for the tip and all that are viewing this
Bowing deeply... Ven Hui Y.  Smile
Falcon67
Posted: 11/05/07 06:19 AM
Good news!  If it's pinging a bit at part throttle, some Ford distributors have an adjustable vacuum advance canister.  If not, they are available aftermarket.  You can take out a few degrees of vacuum advance to help.  You can also try a colder plug - the normal plug is an Autolite 25, Walmart carries 24s on the shelf and those are one step colder.
ltdmonk
Posted: 11/05/07 10:19 AM
i think the accels 576 plugs were cooler(24), it did it.now i installed autolite 25, still does it. i will find my allens? to adjust the advance...
thanks Falcon67  Bowing deeeply Laugh
ltdmonk
Posted: 03/02/08 09:50 PM
well this will close this post.   My LTD is in "meditation". this has been done before. I fired up last april(parked since oct/04)for an emergency use, and after 8,000 miles, it's gonna go back to quiet mode. I got a 351W/AOD on stand by for it. and will share in detail the work involved, need time and more to finish...  stay tuned?
thanking all, Ven. Hui Yu  Ooo  L.A,Ca
bburdick
Posted: 07/28/10 03:43 PM
Hello I plan to build a 400 modified that was in a 70 ford pickup. After reading engine masters john kaase winning of the contest I'm interested on where I can find forged pistons manufacturers for this set up. Question: Do the 400 modified's make good hi performance motors? Who makes a strong bottom end for this application? Any info would greatly appreciated.
Falcon67
Posted: 08/06/10 05:29 AM
You can source everything you might need from http://www.tmeyerinc.com
