getting aftermarket cams
2008blackbullitt
Posted: 12/29/12 07:47 AM
i have a 2008 bullitt and are wanting some big cams to hear that aggressive idle and also high hp gains in the higher rps to shead some time off my 1/4 mile. need some recomendations. also looking for a good bargin and what all i would need in supplies and what i would need to do after instalation.
pepsi1
Posted: 12/30/12 09:17 PM
A little help. Do you have 2V 3V 4V. Automatic trans,or manual?  Be prepared to spend $1,300 on the Cams alone. There are cams that you don't need to modify the coputer,
You will need valve springs. Then depending on how big a cam you want, you will need to modify, computer, big exhaust, bigger injectors, if an auto. more stall speed, larger throttle body, rear gears.
Bob
Meroon991
Posted: 03/04/13 01:52 PM
there are the Hot-Rod cams they are cheap compared to some other cams. also you won't have to change springs or anythings, and they give around 20 horsepower I believe
