FoxBody Headers
90ELIXIR
Posted: 04/14/13 03:47 AM
I have a 90 coupe with a tubuler Kmember-347w/AFR heads-TH350 trany.
What company makes long tube headers that will give me collector clearance around
the trany and crossmember.I want to run 18" long collectors to start with.
What do do racers use, who run power glides? Confused
waynep712222
Posted: 04/14/13 08:09 AM
hmm...  thats an interesting question..  as i am taking you might be running an adaptor plate to mate with the back of the ford block.. so you are having header issues..
there are double hump crossmembers available to clear most exhaust systems..
this is from ford racing     Ford Racing M-5059-A Double Hump Adjustable Transmission Crossmember
41389218 640
there are also tubular versions with bigger humps for more exhaust clearance...
90ELIXIR
Posted: 04/16/13 08:28 AM
Yes I'm using an adapter plate.But the problem is the clearence between the collector and the trany pan on the right side. The crossmember part was solved
by making a new one. The collector on the left side was rubbing against the cross
member bracket,fixed that by massaging it with a BFH. Have everything together,
so I'll live with it for now till I can get the correct fix.But still wondering
how much heat will transfer over from the collector to the trany.
PS: I'm new to all this internet mumbo jumbo.How do I get a jpeg photo from my file
   into my thread like the above picture.
waynep712222
Posted: 04/17/13 07:09 AM
photos...
set up a free photobucket dot com account..  or one of the many other image hosting sites...
up load your images that you want to share there..  once saved...  and you have bookmarked your access...
you can get to your library.. hover your cursor over the thumbnail image.. words will show up.. click on the line that says get links...    look for links that begin with IMG..  click on that and it should copy to your clipboard...
paste that link here ... it will show up as an image.. when you have completed this post..
also.. when logged in.. you can edit your post by clicking  edit post link below left when logged in..
did you know there are also 4 different mustang and ford magazine sites here..  and around 40 different car and truck magazines also..
click my user name for some links..
or this icon at the bottom of the page.. it will open a new window.. then click the OUR SITES tab for a full page of whats here...
Sim
waynep712222
Posted: 04/17/13 07:15 AM
as for gaining clearance.. around the transmission...
there is nothing stopping you from tweaking the headers slightly...
unless they are coated..
they are just steel tube..  a slight twist by inserting something into the collector opening..  might give you a fraction more room..
just a thought... cannot wait to see your images...
oamo111
Posted: 10/04/13 09:46 AM
I'll stay with it for now until I can get the appropriate fix.But still wondering
how much warm will exchange over from the enthusiast to the trany
Authorized Dealeres
