MENU Subscribe to a Magazine
  • Sign in
  • Join
  • Print Subscriptions
  • Digital Subscriptions
  • Gift Subscriptions
  • Subscriber Services
  • Back Issues
  • Personalized Cover
12 Last
P/S control valve on a '68
williaj6
Posted: 02/18/09 10:59 AM
Hello All,
I am sorry to keep bothering you with these stupid questions, but I thought I was going nuts. I purchased a remanufactured bendex valve. Per pictures you all offered my P/S lines look correct. In the tech pictures it shows the return line (larger diameter) on top of the valve with the Pressure line (smaller diameter) on the bottom.  In this assembly my lines would work.  But the control valve I have installed has the pressure line on top with the return line on the bottom.
Result is the pressure line hits the frame on a hard right turn.
Has anyone of you experienced or heard of this?
How do attach pictures?
I have called Cardone Ind. the re-mfg. but they could not help.
Thanks all for your help.
williaj6
Mil1ion
Posted: 02/18/09 02:48 PM
Perhaps it would be better to update the original thread instead of starting another one ?
Maybe a mod can merge them ?
post the part
number of the valve you bought so I can look it up
My Name is Dennis and I approve this message !
"So that is how you shine a skunk ? "
williaj6
Posted: 02/20/09 03:16 PM
Thanks so much for your assistance.  I have got the lines to work.  I gave up on the one piece pressure line, and went to a 2-section pressure line.  Result was the bends in the hard line worked and lines now miss the frame above, with plenty of clearance from the exhaust by the P/S pump.
Regards,
John
williaj6
Toms65stang
Posted: 02/20/09 05:11 PM
THE ONLY STUPID QUESTION IS THE ONE NOT ASKED!!! KEEP ASKING IF YOU DONT KNOW THE ANSWER
williaj6
Posted: 02/24/09 02:26 PM
I know you will know this right off the top of your head.
Problem:
I fail to take a picture of the dash arrangement.
Question:
After repainting the dials on the gauges, I did not put them back on the bench where I got them.  Hence, now I can not remember what side the oil pressure and temperature gauge go on:-))
It is just the old man that I have become.
Thanks, John Grin
williaj6
Mil1ion
Posted: 02/24/09 04:42 PM
IIRC,
oil pressure left
temp right
scott66GT
Posted: 02/25/09 08:25 AM
Hey williaj6 - Some of us use a web site called Photobucket (http://photobucket.com/) to post our photos in preparation for inserting them in our replies on this forum. The Photobucket web site is like any others where you can post photos and they are available for everyone to look at. Generally you have to sign up at no cost in order to post photos and there is a content agreement you must agree to. On the Photobucket web site you sign in, upload a photo from your computer, then you can copy and past it onto the form page where you type your message. At Photobucket you click (left or right depending on your mouse) on the "IMG" (image) code file name (IMG//http://...etc) for the photo you want to copy over and click copy then just past it in into your comment here. It took me a little bit of frustration to figure it out but it is not too difficult. This sure helps others figure out what your trying to explain. Good luck!
Mil1ion
Posted: 02/25/09 01:05 PM
all he did was remove the gauges from the cluster and forgot what side they are supposed to placed on installation .
scott66GT
Posted: 02/25/09 07:45 PM
Hey mil1ion - he did however ask how to post photos.
Mil1ion
Posted: 02/25/09 08:11 PM
Fine..don't believe me
1968 Mustang Cluster Front View
williaj6
Posted: 02/26/09 07:47 AM
Dear Scott,
Thanks for the information. And you are right...a picture says a thousand words.
John
williaj6
williaj6
Posted: 02/26/09 07:52 AM
Dear Milton,
I had to chuckle at myself when I got done painting the dials and set them all in a group.  Then reviewing the wiring...the harness' were the same. I guess I could have traced the sending units.
Thanks,
John
williaj6
williaj6
Posted: 03/03/09 08:09 AM
Hello Milton,
Okay I have another dilema.  I have all the new P/S installed.  I noticed that the control valve will hit the tie rod sleeve when the weight of the car is lowered.  Is there an ajustment I can do with regards to the pitman arm or idler arm placement to offer more clearance?
The new spindles are from Stainless Steel Brakes, all tie rods are new, the tie rod sleeves are from Edelbrock (cool alum. one-piece).
NEXT QUESTION:
I noticed a small anti-freeze drip coming from between the rear of the motor and bell housing-i.e. flywheel.  I suspect I have a freeze plug rusting.
If I remove the C-4 auto transmission and fly wheel...is it possible to replace the freeze plug with the motor in the car?  Do I have enough clearance to hammer a replacement plug?
Kind Regards,
John Williams
williaj6
williaj6
Posted: 03/03/09 08:29 AM
Controlvalvehoseassembly003
williaj6
williaj6
Posted: 03/03/09 08:33 AM
Scott,
Thanks for the information on photos.
Here is a picture of me fuel injection on the air cleaner:-))
Tangbrakes006
Regards,
John
williaj6
12 Last
