2002 mustang convertible lift cylinder needed
ronald09
Posted: 03/26/12 05:53 AM
I need a new lift cylinder drivers side to my 02 mustang convertible;it's leaking from the top of the cylinder. Ford in Naples,Fl says Ford no longer makes them. Does anyone know where I can get the old cylinder restored? I am hesitant to buy an after market
I live in Naples,Fl
Thank you
waynep7122
Guru
Posted: 03/26/12 06:28 AM
seems the ford part number for the cylinder is ... but they do seem to be out of it..
XR3Z7650600AA
Fe8c530771b113675711582b9badfa944
you might want to try a place like
Final2
waynep7122
Guru
Posted: 03/26/12 06:32 AM
if you pick up some  5/16 inverted flair unions... from the autoparts store or hardware store in the brass fittings department..
Dorman - Brass 5/16 Inverted Flare Union
Part # 070660BP  or 785-314
you can remove the hoses from the cylinder and hook them together so the fluid does not leak out and reduces the need to bleed the system...
some parts stores may have in dorman.. or perhaps weatherhead.. a 5/16 inverted flair plug..  those can be installed in the cylinder openings.. or the pump sides when its disconnected to remove and install the pump without spilling..
Orly 120500
Edelmann - Inverted Flared Fitting
Solid Plug - 5/16" Tube (1/2-20 Male Thread)
Part Number: 120500
Line: EDE
MustangMan
Moderator
Posted: 03/26/12 07:22 AM
Check with the folks at Hydro-E-lectric. They are right here in Florida and have quality replacement parts for Ford convertible top systems, including the late-model Mustangs.
Check 'em out at www.hydroe.com. Just put in your year and model and scroll down the parts list to "top cylinder"...
HTH...
Mark
Brand Manager
Mustang Monthly Magazine
1966 Mustang 289-4V/C4 Auto
1990 Mustang 306/AOD
TROJANII
Posted: 03/26/12 01:47 PM
That is who I used, very pleased with them.  You might consider replacing both sides (if one side went out, how much life is left in the other side?) and hoses too.
ronald09
Posted: 03/26/12 04:06 PM
Thank you; after many many ph calls I finally found a store that has the 2 lift cylinders in Inverness, Fl (www.topsdown.com) I should get them in a day. I am going to have a mechanic do it/I am not that handy. I appreciate all the replys
