MENU Subscribe to a Magazine
  • Sign in
  • Join
Magazine Mustang Monthly
  • Print Subscriptions
  • Digital Subscriptions
  • Gift Subscriptions
  • Subscriber Services
  • Back Issues
  • Personalized Cover
69 mach1 instrument panel not lighting up
paultrav
Posted: 12/08/12 02:00 PM
I was getting some lights to work for the gauges, but after installing LEDs and cleaning all contact points, I get no lights.  Trying to learn how to use the GMT-312 to determine what jack points (1-18), where it contacts the instrument circuit board, are providing what power purpose.  I now am looking for a new circuit board and just ordered a headlamp switch rheostat assembly.  I did ground negative  battery terminal to both the block and the anchor point of the passenger side headlamp.  Any suggests on why I can get anything working is greatly appreciated.
waynep71222
Posted: 12/08/12 06:45 PM
well... are you running a standard headlight switch..
power comes into the headlight switch ... when the parking or headlights are on.. the big resistor gets powered...   output from the resistor goes through the fuse box instrument fuse.. its the smallest fuse.. and on to the cluster illumination bulbs...
so do the other lights work.. do you get variable voltage at the shortest fuse when the headlight knob is pulled out and you rotate the knob???
ground connections...
between the negative battery and the body.. usually at the inner fender well..
between the back of the engine and the  firewall...
does your engine run??? and the charging system work..
i have a voltage drop test that takes just a few minutes if you have a digital volt meter to verify the grounds are proper ..
at least the main grounds...
Voltagedroptesting
paultrav
Posted: 12/09/12 04:44 PM
Thank you for your advice and three minute check list I haven’t finished yet.  I think I sheared something in the standard headlight/rheostat gismo when putting it back together.  I forgot about the spring retainer pin on the assembly body and pushed to hard I think.  The knob pin won't lock onto anything now.  Ordered a new switch assembly.  Still looking a for an instrument panel circuit board replacement.  Just eyeballing I see a brake in the top copper line in the plastic.  I think I will get a digital meter as well.  I can't see how to measure 12.65 with my needle reading version.  I found the fuse box and the smallest fuse you mentioned was missing.  I did have luck at one point with the LED lights for the speedometer and alternator working and right hand turn signal, seatbelt, and brake system display light as well without that little fuse there.  Now only the RH signal, and high beam indicator light up without the fuse (I'm yet to have that size fuse).  I hope to find what the numbers (1-18) on the wire jack for the instrument circuit board represent.  After the pieces arrive, I will post an update.   Thanks again.
waynep71222
Posted: 12/09/12 05:46 PM
you might want to read this thread a few months ago... on 69 dash board printing circuits...
http://forums.mustangmonthly.com/70/9288567/mustang-restoration/instrument-cluster-wiring/
this covers a replacement harness for the WRONG Cluster...
paultrav
Posted: 12/10/12 09:29 PM
Thanks again, I haven't checked to see if the cardboard spacers for the gauge bolts have wilted.  I have taken the instrument assembly out several times and may have bumped it.  I'm thinking while waiting for the circuit board and headlight switch, now is a good time to get the stock PHILCO am rebuilt for fm as well as try cleaning the clock before going digital. Would you have suggestions on who to do that or past postings on how?  Any suggestions on what other components I should order while the dash is out is appreciated.
paultrav
Posted: 01/01/13 09:35 PM
I was fortunate with the new circuit board and LED lights.  Nice to see bright panel.  But I am having problems with the headlight knob command shaft catching on the retaining pin in the new rheostat assembly.  I am using the original rheostat again (was going to replace it just in case).  I also am trying to clean out and oil the clock assembly, but can't straighten out the bent-in metal housing tabs used to retain the plastic clock face.  They seem to spring back after prying them out.  I almost broke the clock face from tension.  Any secrets for disassembling/cleaning would be gratefully appreciated.
So Im thinking that now is the time to change the 40 y/o vacuum hose controlling the ac/heat assembly, but I can't figure out if I can take the hoses off the rubber block/manifold that the hoses gather at for the control lever.  I haven't tried the actuators on the assembly and hoping they will work.
