MENU Subscribe to a Magazine
  • Sign in
  • Join
Magazine Mustang Monthly
  • Print Subscriptions
  • Digital Subscriptions
  • Gift Subscriptions
  • Subscriber Services
  • Back Issues
  • Personalized Cover
Help with antenna replacement on 66 mustang
wrightm
Posted: 05/08/13 06:05 PM
Hello,
I was wondering if there is a guide to how to replace a broken antenna on a 66 mustang. I can take it off easily enough by loosening the bolt, but it looks like the the antenna and wire to the inside of the car is all continuous, and would require cutting/splicing the wire or maybe removing the fender? I'm guessing there is an easier way? I'm hoping
thanks,
Micah
waynep712222
Posted: 05/08/13 06:19 PM
must replace ENTIRE antenna and wire COMPLETLY.... NO CUTS AND SPLICES..
its NOT impossible.. it just takes a little longer...
hint.. use some vacuum hose.. taped to the wire to pull backwards thru the openings toward the fender...    attach vacuum hose to the end of the new antenna wire and pull back thru...
Smile
JK65
Posted: 05/10/13 11:15 PM
Be patient tape a guide to the end that plugs into the radio and work it through the hole.  It looks very difficult until you start and then it is not to bad.  When I replaced my 65 I cut the old wire to get it out easier.  Metal guide that will move is the easiest to use.  Tape it to the plug that goes on the radio and from outside the car start threading it through until you can get it from under the dash then slowly pull ( it helps to have another person).  When you get to the grommet good luck.  Trying to get the grommet to pull through inner fender was very tough.
