MENU Subscribe to a Magazine
  • Sign in
  • Join
Magazine Mustang Monthly
  • Print Subscriptions
  • Digital Subscriptions
  • Gift Subscriptions
  • Subscriber Services
  • Back Issues
  • Personalized Cover
torque specs ...please
gezzer
Posted: 05/10/13 01:38 PM
67 mustang v8 upper control arm shaft bushings, what is the torque spec. *** find it in the shop manual. Thanks
waynep712222
Posted: 05/11/13 07:03 AM
the bolts that go thru the upper shaft and stick thru the shock tower... one source says 75 to 100 foot pounds..   there is a LOT of force on those bolts..  as the spring is pushing them down  with significant force... and the input from the suspension action as the car moves over rough pavement and around corners..
i will have to dig deeper if you still need the specs...  usually the NUTS on the inside are tightened as the  bolts usually have a knurl to prevent them from spinning and coming loose in the upper control arm shaft..
gezzer
Posted: 05/12/13 05:55 AM
Thanks for that, but I have the specs for the through shock tower bolts and yes they are 75 to 100 lbs. according to the shp manual. What L'M asking for is the torque spec of the nuts (where the qrease fits are )that secure the shft bushings and shaft to the control arm.
Gezzer
waynep712222
Posted: 05/12/13 06:35 AM
i even looked in my mitchell manual... tight... but they missed the spec..
one site says 25 to 35.. another says 35 to 45 foot pounds ...
be careful that the threads in the control arm are NOT STRIPPED.. its easy to foul up..  the shaft needs to also be centered..
since you are working with a threaded shaft also...   you have to get it right.. or the shaft will push out on the bushings and prevent them from threading in...
its been 30 years since i replaced any of these... i normally if its worn out.. toss a new upper control arm on as i usually find them destroyed once i take them apart..  although upper control arm prices have been going thru the roof  for some reason at least where i was buying them..   looks like 60 to 85 is a normal range  and a few good deals..
i bet that there is a detailed article on replacing the upper control arm bushings with the torque specs.. but i could not find it this morning..  or even  when i looked around yesterday..
gezzer
Posted: 05/12/13 04:33 PM
My friend that shoulds and fells about right, I'll go with 40lbs and go from there.
This is a negative camber wedge camber instalation that found the shafts so tight we could hardly twist them in vise.Another interestinging development is that since we converted to 68 front disc brakes the new lower control arms bought do not line up with the strut rod bolts so there is obviusly a difference from 67 to 68. I guess I'll either reuse the ones I have or get new 68 ones. Much appreciated your help, any further suggestions invited.
Gesser
waynep712222
Posted: 05/12/13 04:50 PM
520 397 001
520-397
1973-68 Ford Mustang
OE#: D10Z-3078-A
520 396 001
520-396
1967 Ford Mustang
OE#: C70Z-3078-B
520 395 001
520-395
1966-64 Ford Mustang
OE#: C4DZ3078A
waynep712222
Posted: 05/12/13 04:59 PM
520 105 001
520-105
1977-66 Ford Mustang, Cougar, Comet, Fairlane, Torino & Cylones not mustang II's  think maverick
OE#: C5DZ 3082-C
OE#: D00Z 3082-A
OE#: D5DZ 3082-C
520 229 001
520-229
1966-64 Ford Mustang,Falcon, Ranchero & Comet
OE#: C4DZ 3082-B
NOTICE THE DIFFERNCE in the space between the shaft mounting bolts
waynep712222
Posted: 05/12/13 05:14 PM
i am still listening to this video on upper control arm shaft installation.. for solid bushings
i don't know if i would cut the channel.. as i think it might flow around the threads..  but thats just the way i think... its probably a good idea..
http://www.youtube.com/watch?v=4Xss9MeMLnM
enjoy...
this is not my video... but it describes things well so far..
waynep712222
Posted: 05/12/13 05:15 PM
doh!! there is a part 2 also... another 8 minutes...
gezzer
Posted: 05/13/13 09:43 AM
Your the man waynep71222,nice video. Looks like I'm set to go. Have new lowers coming in a couple of days, so we can get this puppy on the road. Thanks.
Gezzer
