MENU Subscribe to a Magazine
  • Sign in
  • Join
Magazine Mustang Monthly
  • Print Subscriptions
  • Digital Subscriptions
  • Gift Subscriptions
  • Subscriber Services
  • Back Issues
  • Personalized Cover
oil pan gasket
Luke65
Posted: 08/08/13 12:45 PM
Can you change the oil pan gasket on a 65 289 with power steering without pulling the engine
waynep712222
Posted: 08/08/13 07:42 PM
70bird
Posted: 08/08/13 08:59 PM
hello
yes, easy deal, done it about 100 times. simply remove the cross brace and ram at bracket on drivers frame rail and 2 bolts holding idler to the drivers frame rail. pull down suspension by hand and you will have plenty of room.
check to see it the 1 piece gasket from ford will work on your pan if you want. use ultra black high temp silicone gasket maker in the 4 corners. let sit 12 hours before use.
JK65
Posted: 08/30/13 11:48 PM
Use the one piece gasket from fel-pro. Easy job. I was very impressed with the ease of installing this one piece gasket. I was told to make sure cross member goes back on the same way it came off.  Right side must go back on right side.  Don't know how true this is but I made sure to do this.
JK65
Posted: 08/30/13 11:49 PM
