12 Last
Dash Gauges
1970TexasAuto
Posted: 11/06/13 12:21 AM
Having trouble with my gauges on my 67 need help
1970TexasAuto
Posted: 11/06/13 12:25 AM
The Resistor on the back of the dash has constant power on both sides and the gauges r taking off all the way up except for the gas it does not do anytthing any more
waynep712222
Posted: 11/06/13 07:44 AM
on the instrument cluster voltage regulator...
one wire gets switched power..
one wire is to the gauges..
and the mounting tab is GROUNDED to the cluster housing..
but the HUGE question... is  WHERE is the cluster GROUNDED to the body...
and WHERE is the body hooked to the negative battery..???
lets look at this slightly earlier  mustang image..
66 Mustang Cluster Ground Location
if you notice... there is a what is best described as a side forked terminal under the mounting screw for the ICVR...  that is the GROUND wire for the dashboard...
it goes over to the firewall reinforcement...
hopefully there will be a ground strap from the back of the engine to the firewall..
and perhaps.. in addition to that..  a tab part way down the negative battery cable that connects to the body... so it has a negative battery to the body connection on the inner fender...
does your car run???
please spend a minute and run the voltage drop test with your digital volt meter to prove the grounds..
engine running.. headlights on..   digital meter set to 20 volts DC..
1.  Negative to positive battery posts.. 14.1 to 14.8 volts is expected..
2.  Negative post to the engine block.. 0.04 volts DC max.
3.  Negative post to the body.. 0.02 volts DC max..
4.  Engine block to the body.. 0.02 volts DC max..
if you get more than the 4/100 or 2/100 volts across the ground side.. you have a ground issue..
you can run the same test between either the end of a pair of jumper cables laid on the floor and only the negative hooked to the battery... and your volt meter jumping from the end on the floor to the cluster housing..   because there is not a lot of current being used.. i am expecting less than 1/100 volt.. 0.01.. you might need to switch to the 2 volt DC scale .. or run a jumper wire from the end of the negative jumper cable under the car to the cluster housing... see if the ICVR starts working again..
1970TexasAuto
Posted: 11/06/13 08:24 PM
There are no grounds from motor to the body i wll deal with that and let ya know thanks and yes my car runs
waynep712222
Posted: 11/07/13 01:14 AM
65 66 Mustang Ground Cables
Ground Strap 15 Inch Zpsbc9293c1
paint is not a good conductor ..
star washers also...
Fordfirewallground Zps4692e042
waynep712222
Posted: 11/07/13 01:22 AM
this image is PRINTABLE .. its a JPG..  print and paste it to a wall in your shop..
VOLTAGE Drop Testing Zpsb5de8fcf
1970TexasAuto
Posted: 11/07/13 10:07 AM
Wow no wonder eveyone knows you thanks i will do this tonight
waynep712222
Posted: 11/08/13 12:26 AM
Icon Quote1970TexasAuto:
wait.... somebody knows me..  Blush
does this mean that they are talking about some of my posts somewhere other than here??/
1970TexasAuto
Posted: 11/12/13 07:10 AM
No they are not talking about you I just see your post all over this site and I think you have great answers.I installed he grounds last night all the gauges just went all the way up ,can I ground to the bolt holding on the trans to the block the casing is aluminum.Is it possible that the voltage regulater is bad.I will do the voltage drop test tonight and see what I find
1970TexasAuto
Posted: 11/12/13 10:00 PM
0.0 neg to engine going to move my ground to the block
1970TexasAuto
Posted: 11/12/13 10:03 PM
0.00 engine to negative going to move my ground
waynep712222
Posted: 11/12/13 10:07 PM
run the voltage drop test..
post results by number..
1.____
2._______
3._______
4._______
lets start there...
you can run another voltage drop test.. if the above number on 2.,3 and 4 are at or below 0.04 and 0.02 volts ..
find a good ground location under the dash.. and then probe from that body connection to the dash cluster housing.. see if you get 0.00 or 0.02 volts..  you may have to change to the 2 volts SETTING.. and look for a tiny amount of voltage.
remember... we are looking for the voltage drop in a properly connected circuit. as being the 0.04 and 0.02 volts.. this is the resistance of the Copper wire..
if you get more than the 0.04 or 0.02 volts.. you have resistance in the ground circuit that you are measuring..
1970TexasAuto
Posted: 11/14/13 08:14 PM
1.13.7
2.0.00
3.0.03
4.0.03
1970TexasAuto
Posted: 11/14/13 08:17 PM
Replaced ICVR and now it works
1970TexasAuto
Posted: 11/14/13 08:50 PM
but not the gauges
12 Last
