MENU Subscribe to a Magazine
  • Sign in
  • Join
Magazine Mustang Monthly
  • Print Subscriptions
  • Digital Subscriptions
  • Gift Subscriptions
  • Subscriber Services
  • Back Issues
  • Personalized Cover
289 Distributor
jesse66
Posted: 08/24/13 12:43 PM
I just inherited a 1966 mustang and noticed the number one plug wire is not in the number one position on the distributor cap. The number 5 wire is in that position with the number one wire to the right. The wires follow the correct firing sequence and the car runs. Why would this have been done?
70bird
Posted: 08/24/13 02:24 PM
its not a problem, someone simply installed the dist in the wrong clocking position. very common.
jesse66
Posted: 08/24/13 02:36 PM
that is good to know. Does this effect the timing?
Thanks for the help
70bird
Posted: 08/24/13 05:39 PM
no
Tos636
Posted: 08/31/13 08:03 PM
Has no effect on timing, it just means when someone installed the distributor they got it off a tooth or two which just positions the rotor at a different position and was corrected buy simply repositioning the wires. They then adjusted the distributor and timed it normally. No problem.
54packman
Posted: 09/01/13 06:55 AM
you can drop the distributor in , in any of about 20 positions, one for every tooth on the distributor gear, and as long as the motor is set to top dead center of number one cylinder on compression, you then take what ever distributor tower the rotor is pointing to, that will be #1 cylinder, then using the firing order from #1 add the rest of the wires in the direction of the distributor rotation.
cushman350
Posted: 09/02/13 03:17 PM
cushman350
Posted: 09/02/13 03:19 PM
Scratch off the 1 so you cant see it. Like they said, the sequence can start anywhere, counter clock-wise(FORD) as long as the starting cylinder is TDC, compression stroke.
